ElementExist()
Eric
Version: 9.4
ElementExist()
Post by Eric »
Is there a way to check if an element exist? I do not see it the help file, but I am sure it would exist. right?
Eric
Mike Cowie
Version: Anything thru 11.x
Re: ElementExist()
Post by Mike Cowie »
Eric,
In Excel, Rules or Turbo Integrator, you can check if an element exists in a dimension using the DIMIX(DimensionName, ElementName) function. For element name, you can specify the actual element name or a valid alias. If the function returns a 0, the element doesn't exist; otherwise it returns the index of the element in the dimension.
Mike Cowie
QueBIT Consulting, LLC
Eric
Version: 9.4
Re: ElementExist()
Post by Eric »
FANTASTIC! :D
Eric
