Does someone have any ideas on this one?
TM1 9.5 is installed on a desktop PC. When you launch Architect, you see the blue screen appearing, but then nothing. This is the same for Perspectives.
If you look in the task manager, you see several instances of tm1s.exe and tm1a.exe.
The PC runs Win XP Pro SP3, Excel 2003 SP3. The same thing happens with TM1 9.4.
Thanks in advance,
Wim
TM1 Architect and Perspectives do not start
Re: TM1 Architect and Perspectives do not start
The problem is solved. It appeared that multpiple TM1p.ini files were residing on the PC, which was causing the program not to run.
Wim
Wim
