I have a problem of having two elements in SQL query in TM1 when sourcing from ODBC:
Here is the code of query
SELECT
UD_BOM_TICKET.USERS_ID,
FROM UD_BOM_TICKET, .....
WHERE
TICKET_TYPE.TICKET_TYPE_ID = UD_BOM_TICKET.TICKET_TYPE_ID
AND
SUBSTR(ISSUE_DATE,4,6) = IN ( '?pUploadPeriodPrev?' , '?pUploadPeriodPrevPrev?' )
It says that statement failed.
If I include only SUBSTR(ISSUE_DATE,4,6) = '?pUploadPeriodPrev?' - it perfectly works
pUploadPeriodPrev and pUploadPeriodPrevPrev are defined in the prolog.
Please advise how to include two elements in sql query in TM1 ODBC query.
Thank you,
Dimitri
SQL syntax in TM1
- LoadzaGrunt
- Version: LoadzaVersions
Re: SQL syntax in TM1
Lose the equals sign and try it again:SUBSTR(ISSUE_DATE,4,6) = IN ( '?pUploadPeriodPrev?' , '?pUploadPeriodPrevPrev?' )
SUBSTR(ISSUE_DATE,4,6) IN ( '?pUploadPeriodPrev?' , '?pUploadPeriodPrevPrev?' )
- OLAP Product: Cognos TM1 9.1 SP4
- Version: 9.1 SP4
- Excel Version: 2003
Grunt, you are the Legend.
It worked.
Thank you for the quick reply,
Dimitri
It worked.
Dimitri
