Rules Tracer Window
dubs
Version: 9.4
Rules Tracer Window
Post by dubs »
I have a problem with my rules tracer window in that it opens too small and i have to manually resize it to see anything. It's immensely frustrating.
I've looked at the tm1p.ini file but can only find references to the main explorer window, subset window and security window. I therefore can't find a parameter to set to make the window open large enough to view it contents.
Has anyone else had this problem? how did you fix it?
Many Thanks
Herman Moller
Re: Rules Tracer Window
Post by Herman Moller »
It could be that your Rules Tracer window has been corrupted.
I would suggest the following:
1) Exit TM1 on your machine
2) Delete the TM1p.ini file
3) re-start TM1 and in doing so will re-create the TM1p.ini file. This should solve your rules tracer issue.
BTW what version of TM1 are you running?
HTH
Herman
I think the rule tracer takes it size from the cube viewer you launch it from, or maybe the last cube viewer you closed, something like that..
dubs
Version: 9.4
Post by dubs »
Herman,
That worked! thanks for that, i'm using 9.4 out of interest.
Steve,
The tracer window will inherit the size of the last tracer window you resized provided you keep it open, if i closed the tracer window and then open another one it defaulkte4d to it's coprrupted size.
cheers guys
