I have managed to create a dynamic subset by MDX based on one attribute. Is it possible to create a subset based on more than one attribute? Is it as simple as using "And"/"Or" ???
many thanks.
Subset creation by MDX
JFerguson
- Version: 9.5.1
Re: Subset creation by MDX
I have created a dynamic subset in subset editor by recording the expression and filtering on one attribute and then another, so copied it over to TI...
SubsetCreatebyMDX(pRegName,'{FILTER ({FILTER( {TM1SUBSETALL( [Cap_Ref] )}, [Cap_Ref].[Region] = "%Attribute_Name%")}, [Cap_Ref].[Fund_Code] = "%Fund%")}');
But get a process failure & the error log states: Error: Prolog procedure line (13): Could not create dynamic subset:
I'm obviously overlooking something - any ideas???
Hello there
Regarding And/Or, look at Intersect and Union. Here's an excellent tutorial: http://www.bihints.com/book/export/html/68
- Michel Zijlema
- OLAP Product: TM1, PALO
Hi,JFerguson wrote:I have created a dynamic subset in subset editor by recording the expression and filtering on one attribute and then another, so copied it over to TI...
I think there are a few things wrong in your MDX string: if 'Attribute_Name' is a TI process parameter, you can't use the '%parname% notation on the advanced tabs - you should use parname (without the %, so: Attribute_Name) instead. Another thing is that the string includes a double quote, which I think should be a single quote. But if you simply replace the double quote with a single quote the syntax checker will think your string ends there, so you need to write something like
'{FILTER ({FILTER( {TM1SUBSETALL( [Cap_Ref] )}, [Cap_Ref].[Region] = ' | Char(n) | 'Attribute_Name' | Char(n) | ')}, [Cap_Ref].[Fund_Code] = ' | Char(n) | 'Fund' | Char(n) | ')}'
where n is the character code for a single quote.
Michel
Actually the place to get the current updated version of the MDX Primer is http://www.pxbconsulting.com/downloads.html.
JFerguson
- Version: 9.5.1
Thank you for all of your help. I finally ended up with a working solution:
Attribute_Name = pRegion;
Fund_Name = pFund;
SubsetCreatebyMDX(pName,Expand('{FILTER ({FILTER( {TM1SUBSETALL( [Cap_Ref] )}, [Cap_Ref].[Region] = "%Attribute_Name%")}, [Cap_Ref].[Fund_Code] = "%Fund_Name%")}'));
Fund_Name = pFund;
- rollo19
Newbie question - simple subset creation in TI.
I'm trying to create subsets of level 0 'Units' for each 'Unit Group' level 1. I need the subsets for cascading pick lists - pick a group, pick a unit.
My simplistic expression creates the first dynamic subset 'UNK' then aborts with an error: Unable to register subset
In the data-tab:
SubsetName = UNIT_GROUP_CD;
MDXQ = '{[Unit].['|SubsetName|'].Children}';
SubsetCreatebyMDX(SubsetName, MDXQ);
Data source is the subset of Unit Groups from the Unit dimension I am creating the Unit Group subsets in.. conflict?
This seems to do the same but I felt it was verbose; SubsetCreatebyMDX(SubsetName, '{TM1SORT( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [unit].['|SubsetName|')}, 0)}, ASC)} ' );
In the data-tab:
- rollo19
Solved it (talking to to self) - it didn't like to use the same name so I suffixed the subset name with ' subset'
SubsetCreatebyMDX(SubsetName|' subset', MDXQ);
