9.5 - Re-order of a cube
Posted: Fri Feb 26, 2010 10:10 am
by Herman Moller
Been working with 9.5 and so far so good except for the following:
It seems that you can not re-order a cube with more then 2 of the same measure dimension. ie Cube 1 with KPI Measures works fine, but once I try and re-order cube 2 with the same KPI Measures it fails.
I have seen this in Express as well.
Is this a known issue?
Herman
