Hi Everyone,
I'm befuddled by an error on what I would consider a pretty simple rule. This is only part of the rule, but I've written it separately to ensure this is the problem and it appears to be.
['Service Charge % Used] = IF (['Service Charge Criteria'] @= 'Consultant'), .25, STET;
'Service Charge Criteria' is a string element.
The error I'm getting is "Syntax error on or before: ['Service Charg logical expression
Any help would be greatly appreciated.
Christian
Advice on simple rule please...
- Version: TM1 10.2
Re: Advice on simple rule please...
Could it be that you are missing an apostrophe after the word, "Used" in the element name?
---------------------------V
['Service Charge % Used'] = IF (['Service Charge Criteria'] @= 'Consultant'), .25, STET;
- OLAP Product: TM1, CX
- Version: TM1 7x 8x 9x 10x CX 9.5 10.1
- Excel Version: XP 2003 2007 2010
1. Use ['Service Charge % Used'] instead of ['Service Charge % Used]. You missed out the ' from the end of the target area.
2. Use IF (['Service Charge Criteria'] @= 'Consultant', .25, STET); You placed the ) to wrong place.
As is: ['Service Charge % Used] = IF (['Service Charge Criteria'] @= 'Consultant'), .25, STET;
Should be: ['Service Charge % Used'] = IF (['Service Charge Criteria'] @= 'Consultant', .25, STET);
Peter
Peter
Best Regards,
Peter
Peter
- Version: 9.4
- Excel Version: 2003
I actually have that apostrophe in my rule (it's a typo in my original post, sorry).
thanks for the quick feedback though.
- Mike Cowie
- Version: Anything thru 11.x
Hi Christian,Christian wrote:I actually have that apostrophe in my rule (it's a typo in my original post, sorry).
Any reference to string data in a cube cannot use the internal [] cube reference. You need to use a DB function instead for string data like Service Charge Criteria. Very confusing, I know, but to TM1 the [] references are always assumed to return a number in Rules.
Mike
Mike Cowie
QueBIT Consulting, LLC
- Version: 9.4
kpk wrote:1. Use ['Service Charge % Used'] instead of ['Service Charge % Used]. You missed out the ' from the end of the target area.
Peter
Thanks Peter. This is the actual copy and paste from the rules editor (I'm working on another PC, so that's why I didn't copy and paste initially).
['Bank Service Charge % Used' ] = IF (['Bank Service Charges Criteria' ] @= 'Consultant',.25,STET);
I'm still getting the same error. The only thing I can think of that could be the fly in the ointment is that 'Consultant' is a string field that is imported from another cube that uses a picklist for criteria selection; Consultant, Headcount, Payroll, Collections, etc. I'm having serious problems writing conditionals off of a result from a picklist. Thanks again.
- Version: 9.4
Thanks Mike...let me give that a shot.Mike Cowie wrote:Hi Christian,Christian wrote:I actually have that apostrophe in my rule (it's a typo in my original post, sorry).
Mike
- Version: 9.4
Mike...that fixed it!!!
Thanks everyone for the quick responses, you're life savers.
