I was wondering how can you like extract list of user groups within TI to be used with another TI...okay I think that wasy confusing.
For example, I have elements I want to change the security to read, rather than manual doing it...or creating multiple TI for each user group. I'm like looking up at a table in MS SQL and when in a specific table a specific document number has a corresponding payment document number, i want all cubes that has the document number to be locked or read only. So far I can just do it per user group. To make it easier and not to forget to lock the same elements for the user group. I was thinking if it were possible to get the list of user group and apply the same rule. So only the admin can be able to edit or change items for those read only elements.
How to get Usergroup within TI
appleglaze28
- Excel Version: 2003
kpk
- OLAP Product: TM1, CX
- Version: TM1 7x 8x 9x 10x CX 9.5 10.1
- Excel Version: XP 2003 2007 2010
Re: How to get Usergroup within TI
The User / Group information is stored in a cube: }ClientGroups
You can export the data from the cube into SQL and you can update it form SQL.
The Group / Cube security information is stored in a cube: }CubeSecurity
You can see the control "}" objects if you turn the View Control Object in the Perspectives View menu.
Note: do not forget to run the SecurityRefresh function at the end of your processes.
Peter
Peter
Best Regards,
Peter
Peter
- bihints.com
- Version: 9.0.3
Either
. create a view from the cube }ClientGroups and import it in TI
or
.loop through all elements of the }Groups dimension for a given user:
or
user = 'john.doe';
i = DIMSIZ('}Groups');
while(i > 1);
group = DIMNM('}Groups', i);
if(CellGetS('}ClientGroups',user,group) @= group);
#insert code here to do something with that user group
endif;
i = i - 1;
end;
appleglaze28
Data
Is this right?, I'm not sure if I wrote it right cause all I need is to make sure that restriction are made for all groups when it comes to their access to dimension elements. Is it necessary to include the {ClientGroup cube? Since if use {ClientGroup, I need to indicate a user, but this a scheduled run that covers the same process for all usergroups.
Thanks in advance for the help
while(i > 1);
if(CellGetS('}Groups',group) @= group);
CellPutS(so_stat,'}ElementSecurity_base_worksheet_so_number',so_number,group);
endif;
i = i - 1;
end;
Hello
If I understand you correctly, you could just have the All subset on the }Groups subset, as your data source.
In the Metadata & Data tabs, do whatever you need to do. But you do not need to loop in these tabs over another dimension.
Wim
Wim
appleglaze28
Exactly since that specific security setting would be applied to all, I just can't seem to make it work, cause like I have ODBC point to a table to get a specific table a column, and have those elements be matched in a dimension and if that element is found in SQL and is also available in TM1 then he should change the security for the dimension be changed from WRITE to READ. Rather than manually tagging all those available elements as READ or mark all READ and re-tag unavailable elements in SQL against TM1 as WRITE.
