When I am trying to access the Architect from the Pre production environment I am getting the below mentioned error.
TM1 Version: 9.1 SP3
Microsoft: Windows 2003
Please look into the screen shot attached.
Thanks & Regards,
Ashish
Error while logging into TM1 Architect
Ashish_TM1
- Version: 9.1 SP3 32 bit
- Excel Version: 2003
- Error_Architect.doc
- (26 KiB) Downloaded 246 times
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: Error while logging into TM1 Architect
Hi Ashish,
Based on the error message I assume you're trying to start the Architect through a shortcut. Possibly the path to the executable in the shortcut is not correct.
If you right-click on the shortcut, select Properties and click on 'Open File Location', does this guide you to the tm1a.exe or does this lead to an error message?
Michel
Michel
