Diagram is broken after rebuild
Toto
Version: 9.5 Build 9.5.00100.2380
Post by Toto »
I have an Active Form with a diagram on it. After refreshing the diagram crashes (please see attached file). Is it because of wrong usage of an active form or a (known) bug?
Thanks a lot for your help!
Toto
Refresh_error.doc
(359 KiB) Downloaded 263 times
Re: Diagram is broken after rebuild
This is not a bug this is simply the way active forms work!
You cannot link a chart series to active form report rows as this range is deleted and recreated with every active form refresh (which will clear the data series).
If you want to combine a chart with an active form then
- the chart should be either above or below the active form
- the chart should be linked to a static range not the active form
Toto
Post by Toto »
Hello Lotsaram,
thanks a lot for your help!
Toto
