Installing a TM1 service in 9.5 has changed slightly.....
Historically you would need to write the following code in Command Prompt world
TM1sd.exe -install TM1Server "c:\Dev\Tm1server"
NOW IN 9.5
TM1sd.exe -install -n TM1Server -z "c:\Dev\Tm1server"
It has new parameters of -n and -z that was not needed before (or not aware of) in the command prompt.
Examine this in the Operations Guide.
Herman
TM1sd 9.5 install
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: TM1sd 9.5 install
This syntax for installing services was introduced in version 8.1.1 (documented in the release notes). The old syntax was still supported for backward compatiblity reasons - apparently this backward compatiblity stops at version 9.5.
Michel
Michel
