I'm trying to get the cubes's names in a server with the next code throught the APIs.
ServerInt = TM1ObjectListHandleByNameGet(hPool, hServer, Tm1PropertyList, TM1ValString(hPool, cube, 100))
My problem is that after execute this sentence I don't know how to get the names.
I think to understand that I get the result in TM1ValString(hPool, cube, 100), But I don't know if this is true, or how to use the result and get the names, one by one.
For example: If for the server I have to cubes: (Cube1, cube2) My goal is to get those two names.
Thank you very much
List the names of a cube in a server
- Martin Ryan
Re: List the names of a cube in a server
Instead of getting into the API you could cycle through the control dimension }Cubes and ignore any elements that start with a } as they will be control objects
sub getCubeNames()
Dim myDim as string, i as integer, cubeName as string
myDim="server:}Cubes"
for i=1 to application.run ("dimsiz", myDim)
cubeName=application.run ("dimix", myDim, i)
callYourFunction(cubeName)
next i
end subPlease do not send technical questions via private message or email. Post them in the forum where you'll probably get a faster reply, and everyone can benefit from the answers.
Alas, you do not. That is where you PASS the name of the object TO the function.samuvk wrote:I'm trying to get the cubes's names in a server with the next code throught the APIs.
I agree with Martin; don't use the API, his method is much simpler.samuvk wrote:But I don't know if this is true, or how to use the result and get the names, one by one.
Thank you very much
In addition to which you're using the wrong function. You'd already need to know the names to use TM1ObjectListHandleByNameGet, and that would only be returning a handle to the object, not the name of the object.
Getting a list of cubes is actually one of the easier (
Assuming that you already have a user handle (hUser), a handle to the server (hServer) and a handle to a value pool (hPool), you would need to do the following:
1/ Get a value capsule containing the number of cubes:
vhCubes = TM1ObjectListCountGet(hPool, hServer, TM1ServerCubes())
2/ Extract that as an integer value:
i_CubesCnt = TM1ValIndexGet(hUser, vhCubes)
Then use a loop from 1 to i_CubesCnt in which you do the following.
3/ Initialise the string that will hold the cube name. There are other ways of doing this but I do it as:
sCubeName = String$(gIC_TM1STRING_SIZE_DEFT, Chr(0))
You need to do that because the API functions won't clear the previous contents of the variable, so if you have a long cube name (say "ProfitAndLoss") followed by a short cube name (like "Stats") and don't clear the variable, you'll get "StatstAndLoss") returned when you get the second cube's name.)
(Note: gIC_TM1STRING_SIZE_DEFT is a constant that I had defined with a value of 255. Also, the variable itself was declared as a fixed length string; Dim sCubeName As String * gIC_TM1STRING_SIZE_DEFT)
4/ Get a handle to the cube by using its index, since you don't know its name. (i_CubesIdx is being used to loop through the cubes from 1 to i_CubesCnt):
hCube = TM1ObjectListHandleByIndexGet(hPool, hServer, TM1ServerCubes(), TM1ValIndex(hPool, i_CubesIdx))
5/ Get a value capsule containing the cube name from that handle:
vhCubeName = TM1ObjectPropertyGet(hPool, hCube, TM1ObjectName())
6/ Convert the contents of the value capsule to a string:
TM1ValStringGet_VB hUser, vhCubeName, sCubeName, gIC_TM1STRING_SIZE_DEFT
7/ Trim the trailing null characters from the sCubeName variable.
Then do the cleanup; destroy your pool handle, blah, blah.
And I'd also generally check the value capsules using TM1ValType at each step to ensure that they contained what you think they contained and not an error.
I'll bet Martin's method is looking pretty good about now, no?
samuvk
- Version: v9.0
- Excel Version: 2003
Thank you very much both, for your help.
It's true that Martin's method look like easier.
I tried his method, but I don't know why I having the next problem. (I'm working with Visual Basic in Excel 2003 and TM1 Version 9.0)
I attach the problem that I having in a word document calls VB.
Then, I have a different question. I'm trying to work with Visual Basic 2008, so I want to load the Apis libraries, tm1li.dll, tm1api.dll and tm1sip.dll, but I having the problemm that I attach in the word document calls TM1.
Thank you very much again for your help.
- TM1.doc
- Error load TM1 apis libraries
- (298.5 KiB) Downloaded 319 times
- VBExcel.doc
- Error Calling Sub
- (24 KiB) Downloaded 334 times
(For the record, the error was "Compile Error: Expected =")samuvk wrote:Thank you very much both, for your help.
Get rid of the brackets around
TM1ValStringGet_VB(hUser, hName, name, 100)
TM1ValStringGet_VB is a sub, not a function. By having brackets around the arguments you're telling VBA that you expect it to return a value. The procedure itself doesn't; the only value returned is by reference, via the "Name" argument.
(Clarification edit: I am of course talking about when you're calling the procedure, not about the function declaration in the tm1api.bas module which is an entirely different thing.)
So-called Visual Basic 2008 is not Visual Basic, which finished at Version 6 regardless of what Microsoft claims.samuvk wrote: Then, I have a different question. I'm trying to work with Visual Basic 2008, so I want to load the Apis libraries, tm1li.dll, tm1api.dll and tm1sip.dll, but I having the problemm that I attach in the word document calls TM1.
See the FAQ thread heading "Location of API Libraries, .Net vs C/VB and Other Issues" for a link to a useful treatise on the subject by Mike Cowie.
