I'm new here and with TM1 so I kind of lost.
I'm trying to get all the dimensions that certain cube (Let's say CUBE) has, and at the same time try to get all the elements for a certain dimension (Let's say Month).
Could anyone help me with that issue?
Thank you very much all in advance
Get Dimensions and Elements
Re: Get Dimensions and Elements
Get it how? In a TurboIntegrator process, in an Excel worksheet, in a set of rules statements, via VBA?samuvk wrote:Hi all,
For the first request, the function that you need is probably TabDim (which is both a Worksheet function and a Rules function), for the second one you most likely need the DimSiz and DimNm functions.
- Version: v9.0
- Excel Version: 2003
I would like to get for instance the Dimensions of a cube in a rutine of Visual Basic.
Let say that we have a cube calls (Company), where you have dimensions as: Countries, Year, Month, Net Income (Those are the name of the dimensions)
How could I get those names in a Visual Basic rutine?
Thank you very much again
Use Application.Run to execute the TabDim function in a loop until it returns an empty string. (Obviously add error handling and other frills):samuvk wrote:I would like to get for instance the Dimensions of a cube in a rutine of Visual Basic.
Sub ReturnDimNames()
Dim s_DimName As String
Dim l_DimIdx As Long
l_DimIdx = 1
s_DimName = Application.Run("TabDim", "planning sample:plan_BudgetPlan", l_DimIdx)
If s_DimName = "" Then
MsgBox "No such cube!"
Exit Sub
End If
Do While s_DimName <> ""
MsgBox "Dim " & l_DimIdx & " is " & s_DimName
l_DimIdx = l_DimIdx + 1
Loop
End Sub
