Eliminating Security Cubes
Posted: Thu Aug 14, 2008 7:36 pm
My predecessor setup a cube security for dimensions. I want to eliminate it. It is not as simple as deleting the security cube, is it?
Discussing all things TM1, Planning Analytics, PAx and PAW
https://www.tm1forum.com/
I've never had the "pleasure" of needing to do this, but if I did I think I'd prefer to take the server down and move the relevant .cub file out of the data directory. I just get... shall we say, a bad feeling about having a server session which may still think in some corners of its mind that there's security on a dimension. At least if it can't find a .cub file to load, it should start afresh with the dimension completely unsecured.Eric wrote:My predecessor setup a cube security for dimensions. I want to eliminate it. It is not as simple as deleting the security cube, is it?
Indeed I do remember that occurrence. I wanted to hide some TI parameters. The only way was, as Scott confirms, to shut the server down, delete it in the back end, and restart the server. Which took two hours at that particular client.David Usherwood wrote:I believe you can't delete _any_ object starting with } . Martin may remember creating such an object at a client, just to hold some structural stuff, and finding he couldn't get rid of it. I agree with Alan - rename/remove the object on the disc and restart.
OUCH!2 hours
