Enhance Server Space
iliketm1
Version: 9.4
Post by iliketm1 »
Hello World,
Can someone plz give some tips on how to modify the tm1p.ini file to be able to take in more memory - as my cube size is increasing.
Will increasing SGV's help as much?
Thanks!
Re: Enhance Server Space
I'm not sure I understand what you are getting at. The perspectives ini file is client side. All cube data is held in memory server side.
If you are loading up a local server then you will be limited to the amount of physical RAM the client PC has at its disposal.
Martin Erlmoser
OLAP Product: TM1, Cognos Express,..
Version: 9.1.4 FP1
Post by Martin Erlmoser »
at first - optimize the dimension order of your cubes
but attention: you can easily break through the 2 / 3 / 4 Gig limit.
