Security Integration between Cognos 8 BI and TM1 9.5
Posted: Wed Jan 13, 2010 8:46 am
We are facing an issue with security integration.
This is done using the proven practices document in IBM support. However, at one point (on page 9) , it fails to work.
1) Configuration is done properly
2) I can impot user fromCognos BI to TM1
3) The user is assigned as an Administrator in TM1
4) When IntegratedSecurityMode is set to 5, I get the cognos BI link, when TM1 url is executed.
5) When I login with the user name, it authenticates with LDAP
6) But , it gives an error that the user doesn't exist in TM1.
Is it because user is defined as [b]'LDAP\cogadmin'[/b] in TM1?
Shall appreciate your response.
Milind
[size=150][/size]
Milind
[size=150][/size]
