TM1 9.4 FP2 - Active Forms - Sort Data
vaneagle
OLAP Product: Cognos Express and TM1
Version: 9.4 to 10.2
Excel Version: Excel 02 to 10
Post by vaneagle »
Has anyone tried with active forms to sort the data?
By this I mean grouping all apples together, then oranges etc..
like this
apple
apple
apple
oranges
oranges
oranges
Should i be looking to a VBA solution that once the active form has updated, i then go and sort the result of the active form?
These active forms are tricky little suckers as well :mrgreen:
Any other ideas suggestions?
vaneagle
Re: TM1 9.4 FP2 - Active Forms - Sort Data
Hello
I'm curious to see why you have multiple times the same element. Normally active forms are used to represent elements out of a dimension, which are unique by default.
Anyway, here's an example of an MDX statement: http://forums.olapforums.com/viewtopic. ... 324&p=7307
You can also use sort functions withing an MDX statement. Plaese see http://www.bihints.com/book/export/html/68 too.
Wim
vaneagle
Post by vaneagle »
Hi Wim,
In this form it was poor layout on my part, which i have fixed now. :oops:
Still learning about these active forms... Getting there though!
thanks for your help!
I am sure I will nedd to use this in the future, so at least i have a reference point!
vaneagle
