Server Spec
Posted: Wed Dec 23, 2009 1:41 pm
by RLReyes
Folks,
I was informed by our IT dept that our TM1 blade server is up for an upgrade. Our current TM1 blade has 2 dual core cpu with 32GB of ram. The OS is Windows2003 64bit. We have less than 200 users.
What would be an ideal spec in terms of cpu & ram for our new TM1 blade server?
CPU - quad or 6 core???
RAM - 32GB or 64GB or higher...?
I did check out IBM's website and was able to get the base system requirements but wasn't able to get an ideal system requirement.
Thanks in advance...
Re: Server Spec
Posted: Wed Dec 23, 2009 2:13 pm
by Jeroen Eynikel
RAM:
That is the easiest: how much RAM is your current model using and by how much is it growing? Look at peak usage - not average usage. This is something you can determine yourself. There is no added value in having 64GB of ram if your model is only using 20 and it is not growing... Combine that with how long your new server needs to last and you will have your answer.
Keep in mind that depending on your current version of TM1 a TM1 upgrade may also consume more memory in itself. I.e. the trend over the last few years is that new versions of TM1 usually use more memory than the previous one. I don't think this trend is going to reverse.
CPU:
Depends on the typical behaviour of your users. If you have lots of simultaneous read actions and few write actions you should get some benefit out of extra CPU's. I would guess that a good indicator would be is to ask the IT department to monitor the server for a while and see whether it is using all of the current cpu's regularly or not.
Ofcourse the easiest advice: go for the biggest, meanest machine your budget allows. It can't hurt can it? :p
Re: Server Spec
by John Hammond
http://forums.olapforums.com/viewtopic. ... 6130#p6130
Did a bit of this myself a few months back. Needless to say never got the spec but you can get something fantastic for < £10k
Re: Server Spec
Posted: Thu Dec 24, 2009 9:57 am
by Michel Zijlema
Please note that (according to my information) with the new IBM licensing your TM1 license fee is PVU (Processor Value Unit) related. Upgrading to a machine with a bigger total amount of cores will have a license fee 'penalty'.
So going for the biggest possible machine fitting your budget is not necessarily the best option (or at least also determined by the increase in license fee).
Michel
Re: Server Spec
Posted: Thu Dec 24, 2009 12:51 pm
by Jeroen Eynikel
Michel,
I had completely forgotten about that, but indeed at least some of the new licenses are PVU based, which may be a very important cost factor.
I read at one time - though I can't remember where that there was a benchmark called CINT2000 which would be pretty indicative of TM1 performance. I have no idea whether that is still the case.
Jeroen
