9.5 Web and Contributor give Http error - xml
Posted: Tue Dec 22, 2009 3:19 pm
by tomdekuyffer
I have installed 9.5 on an XP machine with the apache web server.
Contributor + installation went fine : I can edit/start/deploy applicationes etc,
but when i try to open a sheet to insert some data , i recieve the error :
'The website cannot display the page
HTTP 405
Most likely cause:
The website has a programming error.
What you can try:
Go back to the previous page.
Which means that - in my humble opinion - the TM1-Web is not reponding to the request.
The TM1 Web service runs on a IIS 5.1, '.net framework 3.5 SP 1 is installed', and the UTF-8 code setting is ok for the apache...
If i try to open the default aspx page of TM1 web , i.e. ' http://localhost/TM1Web/contributor.aspx' ,
i receive the error :
The XML page cannot be displayed
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
A name was started with an invalid character. Error processing resource 'http://localhost/TM1Web/contributor.aspx'. Line 1...
When trying to open other pages from TM1 Web , I get the same error ...
Does anybody know where to go next ?
Re: 9.5 Web and Contributor give Http error - xml
Posted: Thu Jan 14, 2010 7:24 am
by aagrawal12
Even I am not able to open the Contributor with following error on my Local machine
I am able to open it from server.
Posted: Fri Jan 15, 2010 1:51 am
by DuangpornT
just try http://localhost:port/pmpsvc/
(port is your port number that you setup when you installed apache.)
Posted: Mon Jun 25, 2012 6:16 pm
by girishramarao
I'm facing exactly the same issue posted here. Has any one able to find a soultion this. Using Port id did not do anything good for me.
