Counting # of elements by using attributes
Posted: Fri Dec 18, 2009 8:50 pm
I am working on a cube that has the following dimensions: Tickets (ticket number), Date (The day the data was updated), Status (open, closed, etc..), and Measures (Count, # of closed tickets, # of open, etc..). I created 2 attributes for the ticket dimension (Date Opened and Date Closed) both of which are string attributes and contain a date. The Date Opened attribute is never null but the Date Closed attribute can be null. I have a separate process that updates the attributes of the tickets everyday.
When I pull the data in I map a "1" to the cell value by the given status and date. So: Dec 1, 2009, ticket # 12345, Open, Count = 1.
I am trying to create a rule using the measure # of closed tickets = the sum of all the tickets on a given day that have a closed date = the day I am looking at. So If I select Dec 1, 2009, All Tickets, Closed I would like it to read the Date Closed Attribute and if the ticket was closed on that day it returns a 1 at the n level. Then when I select All Tickets, it sums it up.
I have tried numerous rules but I am missing something or I am just way off on the logic. One rule was:
['# of closed tickets'] = if(AttrS('Tickets',!Tickets, 'Closed Date') @<> '' & ATTRS('Tickets',!Tickets, 'Closed Date') @= DIMNM('Date',DIMIX('Date', !Date)), 1,0);
Could someone please point me in the right direction and also give me a best way to feed this rule?
Thanks!
~Kevin
Thanks!
~Kevin
