Check if Consolidation is not zero
Posted: Wed Dec 16, 2009 3:22 pm
i need to able to check if a consolidation contains zero or not with a TI process (or calc if need be)- what i have to do is check whether a value exists against every element of a dimension and set a flag if it does- so far its worked fine for N level elements but it is not working for C level elements- i can only imagine this is because Consolidations do not have values posted against them but derive them by summing it's children.
In effect i need to ask it whether the result of the consolidation is not zero but what the TI process seems to be doing is read the C Element as 0 whether its children total 0 or not.
not asking for any code or anything just want to know if its possible to read the resulting value of C level element because im thinking that TM1 is not set up to work this way and need to start thinking of an alternative solution to my problem.
cheers
cheers
