Tm1 Contributor - auto calculate
Klaus
Version: 9.4MR1
Post by Klaus »
as I worked with Cognos Planning and TM1 I was very courious about Contributor for TM1. Now I tested it but I miss option for activation autocalculation . If you are familar with Contributor-Web it is very inconvenient to press the "calculate" button each time you change a selection.
Does anybody know if there is a possibility to turn on an autmatic calculation?
best regards
klaus
Klaus
Version: 9.4MR1
Re: Tm1 Contributor - auto calculate
Post by Klaus »
I continued my tests and I discovered something ... wenn I start Tm1Web (!) I do not have the Cube-Viewer I know (in the documentation-pdf there screenshots - they look like the Tm1-Web i know). Instead there is also the contributor interface - and in this tm1-web/contributor I can turn on autocalculation.
So does anybody know if the did not correct the documentation or if there are some other problems?
