Character restrictions in cube and dim names
Posted: Sat Dec 05, 2009 9:45 pm
by Fionnuala
Does anyone know if Tm1 would have any problems with non-alpha characters in cube/dim names? e.g. '&'
I'm using 9.4 MR FP2 HF16
thanks,
Fionnuala
Re: Character restrictions in cube and dim names
Posted: Sat Dec 05, 2009 10:17 pm
by Alan Kirk
Fionnuala wrote:Hi,
thanks,
Fionnuala
Technically
most non-alpha-numeric characters should work
most of the time. However I strongly advise against using anything other than alphanumeric characters and the underscore character. There are links to several thread relating to this in the
FAQ post, under the heading "Reasons To Avoid the use of non-Alphanumeric Characters in Dimension or Cube Names". You might want to start with
this one, though I recommend reading the others as well. (Don't assume that this is the full extent of the problems that they can cause, though; chances are that you won't know that they'll cause a problem in a particular set of circumstances... until they actually do.)
Non-alphanumeric object names (in general) can also cause pain if you're trying to write automation programs, though again you often won't know that you're going to have a problem until you actually do and will then have to spend time figuring out what's causing it.
Posted: Sat Dec 05, 2009 11:00 pm
by Fionnuala
thanks for your reply Alan, I'll will stick with the underscore instead of & to be safe
Fionnuala
