Issue With "View Audit Log..."
Posted: Wed Dec 02, 2009 11:04 am
Hi All ,
I am facing an issue with TM1 9.4 FP1 . The issue is that Audit log is not enabled when i right click on TM1 server (It was working previously ). When I checked the data folder , i found that the server log is filled with error message "4404 ERROR 2009-12-02 10:43:08.141 TM1.Audit.PostProcessor Failed to open temp file for processing tm1rawstore.20091130104040". The Same error is repeated for all log files . There is around 15 tm1server.log files . Each of size 102,408 KB . I tried to delete those server log files , but the server log files is getting populated very soon to the same size . The orginal size of data folder was around 70 MB , but now due to this issue the data folder size is 2.2 GB . The tm1 application is also taking much of the RAM memory . The Server OS is windows server 2003 X 64 with 32 GB of RAM .When I checked in task manager , tm1s application is taking 30 GB of memory .
What should I do to get rid off this issue ? Any help/suggesion is really appreciated .
Anoop
Anoop
