ODBC Source from 2 Database
appleglaze28
Post by appleglaze28 »
Is it possible to use databse table data for dimension creation or loading in TM1 TI when each table comes from 2 different databases but resides on 1 actual Database hardware. For example if I'm using MS SQL 2005 AdventureWorks & AdventureWorkDW sample database? If not...how do you accomodate such instances?
SELECT
AdventureWorks.HumanResources.Employee.EmployeeID,
AdventureWorksDW.dbo.DimEmployee.FirstName,
AdventureWorksDW.dbo.DimEmployee.LastName,
AdventureWorks.HumanResources.Employee.Title,
AdventureWorks.HumanResources.Employee.MaritalStatus,
AdventureWorks.HumanResources.Employee.Gender,
AdventureWorksDW.dbo.DimEmployee.DepartmentName
FROM
AdventureWorksDW.dbo.DimEmployee,
AdventureWorks.humanresources.Employee
WHERE AdventureWorksDW.dbo.DimEmployee.EmployeeKey = AdventureWorks.humanresources.Employee.EmployeeID
robchr
Version: 9.4.1 FP03 32-bit
Re: ODBC Source from 2 Database
Post by robchr »
You should be able to, but you might consider making a view and using ODBC to query the view. ODBC is a little bit flaky, so best to uncomplicate the query from TM1 to SQL Server.
You can even query databases from separate servers.
Version: PA 2.0.7
Post by jim wood »
I agree, I'm not sure how TM1 would a where statement when using 2 different databases.
appleglaze28
But for ODBC you need to create a ODBC Driver for each data source. So what's the best approach when you need to combine 2 data sources either for creating hierarchy dimension or cube loading.
