Help with a Feeder
Paul-TM1
Help with a Feeder
Post by Paul-TM1 »
I need help with a feeder. For some reason, it's not working for a few elements. The rule is working but the feeder works partially.
Can you please tell me how to fix it?
Source Cube Dimensions Feeder
Labor_ASDF Employees_ASDF
Months
Projects
Versions
Labor Calcs
['Hours']=>DB('SumCostIWO1-LaborSummary',!Projects,!Employees_ASDF, DB('Labor-ASDF',!Employees_ASDF,!Months,!Projects,'Forecast','PLC') ,!Months,!Versions, attrs ( 'Employees_ASDF' ,  !Employees_ASDF, 'EmplGroup' ), 'Hours');
['Cost']=>DB('SumCostIWO1-LaborSummary',!Projects,!Employees_ASDF, DB('Labor-ASDF',!Employees_ASDF,!Months,!Projects,'Forecast','PLC') ,!Months,!Versions, attrs ( 'Employees_ASDF' ,  !Employees_ASDF, 'EmplGroup' ), 'Cost');
Target Cube dimensions Rule
SumCostIWO1-LaborSummary Projects
Employees_ASDF
PLC
Months
Versions
Companies
Labor Calcs
['Hours'] = if (
	attrs( 'Versions', 'Forecast', 'LiveVersion') @='Y' &
	 !Companies @= attrs ( 'Employees_ASDF' ,  !Employees_ASDF, 'EmplGroup' )&
	!PLC @= DB('Labor-ASDF',!Employees_ASDF,!Months,!Projects,!Versions,'PLC'),
	DB('Labor-ASDF',!Employees_ASDF,!Months,!Projects,!Versions,'Hours'),
	CONTINUE
['Cost'] = if (
	DB('Labor-ASDF',!Employees_ASDF,!Months,!Projects,!Versions,'Cost'),
	CONTINUE
Paul.
Elessar
OLAP Product: PA 2
Version: 2.0.9
Re: Help with a Feeder
Post by Elessar »
Hello!
That's a very well structured question!
I assume the cause here is that after Employees_ASDF attribute or "DB('Labor-ASDF',!Employees_ASDF,!Months,!Projects,!Versions,'PLC')" changes, rule uses new value, but feeder remains in the old value. Feeder fires once when rule is saved or when value is entered to source cell. But it does not know if anything changes in attributes or cell values used in DB.
You can also refer to question #7 in my quiz :) viewtopic.php?p=83204#p83204
#tm1forumalive
Paul-TM1
Post by Paul-TM1 »
Hi Elessar,
Thanks for the reply.
I understood that the PLC should also be fed and have added another feeder as below and refreshed the feeders and it did not help.
['PLC'] =>DB('SumCostIWO1-LaborSummary',!Projects,!Employees_ASDF,
		attrs ( 'Employees_ASDF' ,  !Employees_ASDF, 'EmplGroup' ),'PLC') ;
Paul.
Paul-TM1
Post by Paul-TM1 »
Found the issue. I have hard coded the version in the feeder.
Paul
MarenC
Excel Version: Excel 2016
Post by MarenC »
Would have been good if this:
was this:
For some reason, it's not working for a few versions!
But good that you told us the problem and managed to resolve it.
Maren
