Need hele with Rule
Paul-TM1
Need hele with Rule
Post by Paul-TM1 »
I need help with a rule.
['Hours'] =N: if (
	attrs( 'Versions', 'Forecast', 'LiveVersion') @='Y'
	& !Companies @= attrs ( 'Employees' ,  !Employees, 'EmplGroup' )
	& !PLC @= DB('Labor-ASDF',!Employees,!Months,!Projects,!Versions,'PLC')
	DB('Labor-ASDF',!Employees,!Months,!Projects,!Versions,'Hours')
	CONTINUE
In the rule, I am getting an error on two lines
and
On both lines, I get invalid string expression. I have verified and 'PLC' in both cubes is a string and the same measure dimension "Labor Calcs" common in both cubes.
And 'Hours' is a number from the same measure dimension "Labor Calcs" common in both cubes.
Can someone help? stuck on this for more than 2 hours.
Paul.
Re: Need hele with Rule
First the basics: are the dimensions Employees,Months,Projects & Versions all in the cube? Otherwise you will get a invalid string error for any attempt to reference !dimension if the dimension doesn't exist in the cube.
Have you tried reversing the test? Sometimes TM1 just doesn't like string comparison tests with !dimension leading and it just needs to be on the other side of the = e.g.
DB('Labor-ASDF',!Employees,!Months,!Projects,!Versions,'PLC') @= !PLC
Question: If Versions is part of the cube why is 'Forecast' hardcoded and not using a !Versions reference? This looks odd to me.
Paul-TM1
Post by Paul-TM1 »
Thanks Lotsaram.
Fresh set of eyes fixed the issue. There was one dimension missing in my rule. Your pointing to basics made me check.
Paul.
