1. Can we publish PAW Applications from PAW to Cognos Analytics? I have searched and did not find anything.
2. While searching for the first question, I found that we can publish from PAX to Cognos Connection and I don't see a way for that. How is the connection set up?
Can someone please send me the documentation links?
Paul.
burnstripe
- Version: 2.0.9
Re: Can we publish PAW Applications from PAW to Cognos Analytics
PAW applications cannot be published to Cognos Analytics. However Cognos Analytics could display/embed the webpage/PAW application within an iFrame.
The pax to Cognos connection I suspect won't give you what you are looking for
Outside of nesting the application, new reports could be built in Cognos Analytics based on planning analytics but the connection is limited to metadata/data rather than reports/applications
What business problems, issues are you trying to address by trying to publish paw applications to Cognos Analytics? Knowing that someone could advise on which path you could take.
Paul-TM1
Thanks Burnstripe.
I was curious if it's possible. We currently publishTM1 applications (contributor) into Cognos and thought it could be possible and I am new to PA 2.1.
Paul.
Paul.
