CreateHierarchyByAttribute Issue
MarenC
Excel Version: Excel 2016
Post by MarenC »
I am trying to use the CreateHierarchyByAttribute function in Planning Analytics and am receiving the following error:
Error: Prolog procedure line (22): DIMENSIONHIERARCHYCREATE: Cannot create hierarchy "Code Region": dimension "Code" already has element names/aliases containing metacharacters.
The code is:
sCodeDim = 'Code';
sCodeAttr = 'Code Region';
sTotal = 'Total Regions';
sDefault = 'Region Undefined';
IF( HierarchyExists( sCodeDim, sCodeAttr) =1);
	HierarchyDestroy( sCodeDim, sCodeAttr);
ENDIF;
CreateHierarchyByAttribute( sCodeDim, sCodeAttr, sDefault, sTotal);
Has anyone encountered this issue? Given the error message I assumed that some characters are not allowed in hierarchies, which was a surprise to me, given they are ok in the main hierarchy. I should stress it appears it is the element names and not the alias causing the issue.
As a test I deleted most of the elements from the dimension bar a few and ran the process again, and it ran successfully.
I then decided to delete the new hierarchy I had created by running: HierarchyDestroy( sCodeDim, sCodeAttr);
Then when I went to update the Code dimension I got the following error:
Error: MetaData procedure line (0): Serious system error, Dimension not updated
It would appear that by destroying the hierarchy it had corrupted the dimension.
Maren
Re: CreateHierarchyByAttribute Issue
CreateHierarchyByAttribute is strictly demoware. It is completely un thought out, e.g. it can only be run once and fails if the target hierarchy already exists so.
Adam
OLAP Product: IBM PA
Version: 2.0.9.x
Post by Adam »
Do you get the error still if you SaveDataAll; in the if statement after HierarchyDestroy?
Take care,
Adam
As Lotsa implies, please disregard from that function and do it the proper way.
HierarchyElementInsert
HierarchyElementComponentAdd
Destroy parent-child relations and so on
