Custom indentation for dimension dlements in PAfE
biggie
OLAP Product: IBM TM1
Version: 2.0.88
Excel Version: 2019
Post by biggie »
Hello. Is it possible in a PAfE dynamic report to set a custom number of indents for some dimension elements in the rows, for example, through formatting?
I have this test dynamic report. I would like the elements f1, f2, f3, f4 to have a different number of indents (which I can configure), not based on their level in the hierarchy.
I assumed this could be done using Increase Indent in the cell formatting (B2:B5), but it doesn't work.
Thanks for your help.
Re: Custom indentation for dimension dlements in PAfE
Hi, You may want to try setting the indentation argument of the TM1RptROw formula to 0. I suspect it is overriding your custom formats.
https://www.ibm.com/docs/en/planning-an ... -tm1rptrow
