how to connect PAfe client to TM1 Server directly via RestAPI?
wang_chris
Post by wang_chris »
TM1 Admin server and TM1 Server are run on my local machine (windows), there is no PAW installed.
I run PAfe client (pa_excel_2.0.91_64b_win_ml.xll) with excel, and can see 'IBM Planning Analytics' panel appear on excel command bar. But when I tried to create a new connection to TM1 server with below setting:
    Data Source Type: IBM Planning Analytics
    Connection URL: https://localhost:12662/api/v1       # (12662 is defined in my tm1s.cfg as HTTPPortNumber)
    Friendly Name: a
the connection test returns success. However, when I saved this connection and make a real connection with it, system reported an error with below message "can not find below webpage: https://localhost:12662/api/?ttps://loc ... 662/api/v1". I don't know why it repeats my input URL.
I can get json information return when I input URL "https://localhost:12662/api/v1/Configuration" on the browser directly. and my tm1s.cfg setting as below:
    IntegratedSecurityMode=1
    UseSSL=T
    AdminHost=127.0.0.1
    PortNumber=12660
    ClientMessagePortNumber=12661
    HTTPPortNumber=12662
My question is
1) can PAfe directly connect to TM1 Server by RestAPI without PAW?
2) if above solution works, how should I set the connection URL? and should other parameters be set?
Re: how to connect PAfe client to TM1 Server directly via RestAPI?
Hi Chris,
I'm afraid it is not possible to connect PAfE direct to the TM1 DB, it must go via PAW.
Adam
OLAP Product: IBM PA
Version: 2.0.9.x
Post by Adam »
To elaborate a bit more, all the screens for cube viewer and set editor are webview2 screens from PAW. Without PAW, PAFE is not usable.
Take care,
Adam
