I'm in PAW. I think we're 2.0.0.84.
I have a TI process where the data source is a named view tiListSalesYTD. My goal is to change the TI to do the exact same thing but make the view in the prolog. I will post the code after this to both processes. I opened the current process and saved it as a new name. In the new TI I changed the data source from the tiListSalesYTD view to the cube's default view. I then added code to make a temp view TempListSalesYTD based on a mdx. I run it and it makes the view ok. The MDX matches the old view exactly. However there are no loops through the metadata or data tabs. If I change the data source of the old code from tiListSalesYTD to Default same thing happens. If I change the data source of the new TI to tiListSalesYTD it works.
Here's the original code. This is the version of the TI with the data source of tiListSalesYTD
#Section Prolog
# Author: Rick Stevenson
# Created: 1/14/2007
# Company: ARCS Solutions LLC
# Client: <Client Name>
# Definition: Creates the BPM Office Non Category Off Invoice Data
# Copyright: ARCS Solutions LLC, 2008, All Rights Reserved
### *** Start - SetUp and call Hartz standard Audit/EOJ Process ***
vtiProcName = GetProcessName();
vExecUser = TM1USER();
vNow = TIMST(NOW,'\Y-\m-\d \h.\i.\s');
vOutputDirectory=CELLGETS('cn_control','Output Directory', 'String');
vERRFile= vOutputDirectory | TRIM (vtiProcName) | '_' | vNow | '.err';
vLocation = 'BEGIN';
vSendVerbose = 'N';
vSendMail = 'N';
vReturnValue = ExecuteProcess('Htz BPM std Audit-EOJ', 'pSendExecUser', vExecUser, 'pSendProcName', vtiProcName, 'pSendLocation', vLocation, 'pSendMail', vSendMail, 'pSendVerbose', vSendVerbose);
if(vReturnValue = ProcessExitSeriousError() );
ASCIIOUTPUT(vERRFile, 'Process exited with serious errors at', TIME, 'on', TODAY);
endif;
### *** Finish - SetUp and call Hartz standard Audit/EOJ Process ***
vCubName = 'rp_sales' ;
vCubControl = 'cn_control' ;
vSendValue = 1 ;
vExport = 1;
vZeroSendValue = 1 ;
vHeaderRowCount = 0;
vExportHeaderRowCount = 0;
#=============== DEFINE Static Variables ========================
vBookOriginal = 'Original' ;
vBookAllocation = 'Allocation' ;
vBookPreAllocation = 'Pre-Allocation';
vScenario = 'Actual' ;
vCurrency = 'Local';
vEntity = 'No Entity';
vAllProduct = 'All Business Groups' ;
vMonth = CELLGETS ( 'cn_control' , 'Process Sales Month' , 'String') ;
vTiName = 'Htz BPM EX Non Category Off Invoice Allocation';
vDimNameTi='}Processes';
vDimCustomer = 'Customer' ;
vDimProduct = 'Product' ;
vNow = TIMST(NOW,'\M \D, \Y at \H \p \i min \s sec');
ATTRPUTS(vNow,vDimNameTi,vTiName,'Start Time');
vDownloadDirectory = CELLGETS('cn_control','Download Directory' , 'String');
vLogFile = vOutputDirectory | TRIM (vTiName) | '_' | vNow | '.log';
vExportFile = vDownloadDirectory | TRIM ( vTiName) | '.csv' ;
vErrorFile = vOutputDirectory | TRIM (vTiName) | '.err';
#PROCESSQUIT;
#Section Metadata
#Section Data
#======== Using Metadata tab to process only categories with blank Business Group attributes =============
IF ( vSendValue = 1 ) ;
#======================== NON CATEGORY O/I =================================
#==================== ALLOCATION BASIS CALCULATION =========================
vListSalesAll = CELLGETN ( vCubName , Book , Scenario , Currency , Entity , Customer , Location ,
Territory , vAllProduct , vYear , vMonthYTD , profitability_msr ) ;
vRatio = Value \ vListSalesAll ;
#============================= SPOILS =====================================
vProfitabilityMsr = 'Non Category Off Invoice Spoils' ;
vNonCategoryOI = CELLGETN ( vCubName , vBookPreAllocation , Scenario , Currency , Entity , Customer , Location ,
Territory , vAllProduct , vYear , vMonth , vProfitabilityMsr ) ;
IF(vExportHeaderRowCount = 0);
ASCIIOUTPUT ( vExportFile , 'vCubName' , 'vBookAllocation' , 'Scenario' , 'Currency' , 'Entity' , 'Customer' ,
'Location' , 'Territory' , 'Product' , 'vYear' , 'vMonth' , 'vProfitabilityMsr' , 'vNonCategoryOI' ) ;
vExportHeaderRowCount=1;
ENDIF;
IF ( vExport = 1 ) ;
ASCIIOUTPUT ( vExportFile , vCubName , vBookAllocation , Scenario , Currency , Entity , Customer ,
Location , Territory , Product , vYear , vMonth , vProfitabilityMsr , STR ( vNonCategoryOI * vRatio , 20 , 5 ) ) ;
ELSE;
CELLPUTN ( vNonCategoryOI * vRatio , vCubName , vBookAllocation , Scenario , Currency , Entity , Customer , Location ,
Territory , Product , vYear , vMonth , vProfitabilityMsr ) ;
ENDIF;
#======================== SPOILS OVERSPEND ==============================
vProfitabilityMsr = 'Non Category Off Invoice Spoils Overspend' ;
ENDIF;
ELSE;
ENDIF;
#========================== BROKER RESETS =====================================
vProfitabilityMsr = 'Non Category Off Invoice Broker Resets' ;
ELSE;
ENDIF;
#==================== BROKER RESETS OVERSPEND ==============================
vProfitabilityMsr = 'Non Category Off Invoice Broker Resets Overspend' ;
ELSE;
ENDIF;
#=========================== BACKHAULS ===============================
vProfitabilityMsr = 'Non Category Off Invoice Non Terms of Sales - Backhaul' ;
ELSE;
ENDIF;
#===================== VOLUME DISCOUNTS =============================
vProfitabilityMsr = 'Volume Discounts' ;
#===================== Different from top vListSalesAll pulling 'All Locations' ============================
vListSalesAll = CELLGETN ( vCubName , Book , Scenario , Currency , Entity , Customer , 'All Locations' ,
Territory , vAllProduct , vYear , vMonth , profitability_msr ) ;
vNonCategoryOI = CELLGETN ( vCubName , vBookPreAllocation , Scenario , Currency , Entity , Customer , 'No Location' ,
'No Territory' , vAllProduct , vYear , vMonth , vProfitabilityMsr ) ;
ELSE;
ENDIF;
ELSE;
IF(vHeaderRowCount = 0);
ASCIIOUTPUT ( vLogFile , 'Book' , 'Scenario' , 'Currency' , 'Entity' , 'Customer' , 'Location' ,
'Territory' , 'Product' , 'Year' , 'Month' , 'Profitability Msr' , 'Category OI Profitability Msr') ;
vHeaderRowCount=1;
ENDIF;
ASCIIOUTPUT ( vLogFile , Book , Scenario , Currency , Entity , Customer , Location ,
Territory , Product , vYear , vMonth , profitability_msr , vProfitabilityMsr ) ;
ENDIF ;
#Section Epilog
#================ This will load into the }ElementAttribute_Processes cube ========================
#================ The time this process Ended when it was last run. ========================
ATTRPUTS(vNow,vDimNameTi,vTiName,'End Time');
vLocation = 'END';
vSendVerbose = 'N';
vSendMail = 'N';
endif;
#Section Prolog
# Change History
# 5/28/25 INT290 Replace static views with dynamic view created by mdx. Rename TI process to current standard
vSendVerbose = 'N';
vSendMail = 'N';
vDataSourceView = 'TempListSalesYTD';
endif;
vSendValue = 1 ;
vExport = 1;
vTiName = GetProcessName();
# see if the dynamic zero out view exists and destroy it if it does. It is temp view and should never exist. This is a safety step
IF (ViewExists( vCubName, vDataSourceView ) = 1);
ViewDestroy( vCubName, vDataSourceView );
ENDIF;
# set the MDX for the dynamic view
vDataSourceMDX = 'SELECT
} ON 0,
[book].[book].[Original]
[scenario].[scenario].[Actual]
[currency].[currency].[Local]
TM1SubsetToSet([entity].[entity],"mdxLeaf","public")
TM1SubsetToSet([customer].[customer],"mdxLeaf","public")
TM1SubsetToSet([location].[location],"mdxLeaf","public")
TM1SubsetToSet([territory].[territory],"mdxLeaf","public")
TM1SubsetToSet([product].[product],"mdxLeaf","public")
TM1SubsetToSet([year].[year],"mdxProcessSalesYear","public")
TM1SubsetToSet([month].[month],"mdxProcessSalesMonthYTD","public")
[profitability_msr].[profitability_msr].[List Sales]
} ON 1
FROM
[rp_sales]';
# create the view
ViewCreateByMDX( vCubName, vDataSourceView, vDataSourceMDX, 1 );
# set View parameters
# exclude consolidated values
# include rule calculated values
# exclude zeros
ViewExtractSkipCalcsSet(vCubName, vDataSourceView,1);
ViewExtractSkipRuleValuesSet(vCubName, vDataSourceView,1);
ViewExtractSkipZeroesSet(vCubName, vDataSourceView,1);
# use the view as the source of this process
DataSourceType = 'VIEW';
DatasourceNameForServer = vCubName;
DatasourceCubeView = vDataSourceView;
#PROCESSQUIT;
#Section Metadata
#Section Data
ENDIF;
ELSE;
ENDIF;
ENDIF;
ELSE;
ENDIF;
ELSE;
ENDIF;
ELSE;
ENDIF;
ELSE;
ENDIF;
ELSE;
ENDIF;
ELSE;
vHeaderRowCount=1;
ENDIF;
ENDIF ;
#Section Epilog
vLocation = 'END';
vSendVerbose = 'N';
vSendMail = 'N';
endif;
EDIT: Forgot to mention I also made it so my new view was not temporary. The mdx of current vs new view is exactly the same.
