Refined VBA Logic for Launching TI Process
WilliamSmith
OLAP Product: TM1 / PA / PAx / PAW
Version: TM1 11
Excel Version: 365
Post by WilliamSmith »
Below is a refinement to the VBA code I use to launch TI processes via the TM1 Rest API. Wanted to share to help our community in case someone finds it useful.
The refinement uses the async polling method. I've found the older sync endpoint has undefined behavior, as far how long it will maintain the http connection. For long running tasks, it would sometimes return to the calling VBA script with no return. This new scripting mitigates that concern.
It requires a VBA reference to:
• Microsoft Scripting Runtime
• Microsoft XML, v6.0
And an external VBA module:
https://github.com/VBA-tools/VBA-JSON
Public Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As LongPtr)
Function TM1_Run_Process_With_Polling(processName As String, Optional paramDictionary As Dictionary, Optional timeoutSeconds = 60) As String
On Error GoTo ErrHandler
    Dim payload As String
    Dim runStatus As String
    Dim responseText As String
    payload = ""
    runStatus = ""
    If Not paramDictionary Is Nothing Then
        payload = "{""Parameters"":["
        For Each Key In paramDictionary.Keys
            payload = payload & "{""Name"":""" & Key & """, ""Value"":""" & paramDictionary(Key) & """},"
        Next
        payload = payload & "]}"
    End If
    Dim x As MSXML2.ServerXMLHTTP60
    Set x = New MSXML2.ServerXMLHTTP60
    x.Open "POST", "https://[YourServer]:[YourPort]/api/v1/Processes('" & processName & "')/tm1.ExecuteWithReturn", False, "[YourUserName]", "[YourPassword]"
    x.setRequestHeader "WWW-Authenticate: Basic Realm", "TM1"
    x.setRequestHeader "Content-Type", "application/json"
    x.setRequestHeader "Accept", "application/json"
    x.setRequestHeader "Prefer", "respond-async"
    x.SetOption 2, 13056
    x.send payload
    Dim asyncId As String
    asyncId = ExtractAsyncID(x.getResponseHeader("Location"))
    Dim counter As Integer
    counter = 1
    Do While True
        x.Open "GET", "https://[YourServer]:[YourPort]/api/v1/_async('" & asyncId & "')", False, "[YourUserName]", "[YourPassword]"
        x.send
        If counter = timeoutSeconds Then
            Err.Raise 17, , "The requested operation timed out."
        End If
        If x.Status = 200 Or x.Status = 201 Then
            responseText = x.responseText
            Exit Do
        End If
        counter = counter + 1
        Sleep 1000
    Loop
    Dim json As Object
    Set json = JsonConverter.ParseJson(responseText)
    runStatus = json("ProcessExecuteStatusCode")
ErrHandler:
    If Err.Number <> 0 Then
        Err.Raise 17, , "VBA Script Error!: " & Err.Description
    End If
    If runStatus <> "CompletedSuccessfully" Then
        MsgBox "Turbo Integrator script error!: " & runStatus
    End If
    TM1_Run_Process_With_Polling = runStatus
End Function
Function ExtractAsyncID(inputString As String) As String
    Dim startPos As Integer
    Dim endPos As Integer
    Dim idLength As Integer
    Dim extractedID As String
    startPos = InStr(inputString, "_async('") + Len("_async('")
    endPos = InStr(startPos, inputString, "')") - 1
    idLength = endPos - startPos + 1
    extractedID = Mid(inputString, startPos, idLength)
    ExtractAsyncID = extractedID
End Function
Example of calling a TI script:
Sub AddNewProjectCode()
    Dim wb As Workbook
    Set wb = ThisWorkbook
    Dim parameters As New Dictionary
    parameters.Add "projectCode", Trim(wb.Names("AlphaCode").RefersToRange.Value)
    TM1_Run_Process_With_Polling "AddNewProjectCode", parameters
    parameters.RemoveAll
    'Save Data
    TM1_Run_Process_With_Polling "savedata"
End Sub
