Need Help Configuring Custom Java Provider Namespace in IBM Cognos Analytics 12.0.4
Posted: Fri May 02, 2025 10:48 am
Hi Everyone,
I'm currently setting up IBM Cognos Analytics 12.0.3 in a production environment, and I need help configuring a Custom Java Provider as the authentication namespace (instead of standard LDAP/Active Directory).
So far:
1. Cognos is installed and working.
2. Content Store is configured with Microsoft SQL Server and services are up.
3. The system is currently logging in as Anonymous since authentication isn't configured yet.
4. I want to integrate a Custom Java Provider (.jar file is available) for authentication, but I need proper guidance on:
4.1. Where to place the .jar file
4.2. What values to enter in Cognos Configuration (Java class name, library path, etc.)
4.3. Any dependencies or restart sequence
4.4 Sample setup if available
So any help to speed this up would be appreciated.
Thanks in advance!
So far:
Thanks in advance!
