How to use a parameter cube in PAW MDX
ice1000
Version: PAX on Cloud
Excel Version: O365
Post by ice1000 »
I have a calculated member in a PAW view. Instead of hardcoding the values in the calculation I would like to retrieve the element name from a parameter cube. I can't figure out the correct syntax.
This is the MDX with the hardcoded values:
WITH
   MEMBER [Scenario].[Scenario].[Plan / Actuals] AS [Scenario].[Scenario].[Plan] / [Scenario].[Scenario].[Actuals], SOLVE_ORDER = 1, FORMAT_STRING = '#,##0.00;(#,##0.00)'
SELECT
      [Period].[Period].[All Years^2020^2020Q2^202004]
   } ON 0,
      [Scenario].[Scenario].[Scenario Hierarchies^Actuals],
      [Scenario].[Scenario].[Scenario Hierarchies^Plan],
   } ON 1
FROM
   [Finance]
WHERE (
   [Finance_Msr].[Finance_Msr].[Original],
   [Company].[Company].[001],
   [Department].[Department].[Total Departments^Sales and Marketing^40],
   [Currency].[Currency].[USD],
   [Account].[Account].[Net Income After Allocations^Net Income^EBITDA^Gross Margin^Net Sales^Sales^410000])
I want the denominator of
to be retrieved from a cube. The cube will have the name of the scenario as a string data point.
I've tried this and I get ERROR in the cube (MDX compiles but I see the word ERROR in the data point):
                [Control].[Control Parameter].[Target Scenario],
                [Controls].[Measure].[String]
I created a dynamic subset that returns the correct scenario using a rule-based attribute. Then I tried this:
STRTOMEMBER("[Scenario].[Scenario].[" + SETTOSTR( TM1SubsetToSet([Scenario].[Scenario] , "TargetScenarioSubset" , "public")) + "]")
That also results in an ERROR value.
How can I do this?
ice1000
Excel Version: O365
Re: How to use a parameter cube in PAW MDX
Post by ice1000 »
For posterity, I got these two to work. I do want to get the TM1SUBSETTOSET to work. Still testing that one.
STRTOMEMBER("[Scenario].[Scenario].["+LOOKUPCUBE( "Control","([Control Parameter].[Control Parameter].[Target Scenario],[Control Measure].[Control Measure].[String])" )+"]")
STRTOMEMBER("[Scenario].[Scenario].["+[Control].([Control Parameter].[Control Parameter].[Target Scenario],[Control Measure].[Control Measure].[String])+"]")
Try Part 7 of my Introduction to MDX for more insights...
BR, George.
To get a member from the subset try something this:
TM1SubsetToSet([Scenario] , "Default").ITEM(0).ITEM(0)
That should return the first member.
TM1SubsetToSet([Scenario] , "Default").ITEM(1).ITEM(0)
Will return the second member.
BR, George.
