DBSEND NOT POPULATING FOR 1 CUBE
R4958
Version: PAfE
Excel Version: 2 0 92 7
Post by R4958 »
Hello
It appears a dbsend has stopped working in a file and I can't determine the cause. It seems to work just fine on the FY24 file (we run Sept-October and recently finalized). The only change we make for the new fy file is to update the fy and the current month. We change the DBSEND column from N to Y and calculate. For the new fy sheet, there is 1 cube that is not populating. It just giving -. We have not changed the process, formula or the cubes since last month when we closed fy24 so I am baffled as to why this is happening. The same process/file has been used for many years. I honestly don't know if any can assist me with this issue without being in front of the computer but any general thoughts on how to troubleshoot would be greatly appreciated. I am thinking something needs to be updated for fy25 in the impacted cube but I just don't see what I am overlooking.
PAW 11.8.02300.10
PAfE 2.0.92.7
Perspectives still active
64bit
Re: DBSEND NOT POPULATING FOR 1 CUBE
You really haven't given any specific information which would help anyone diagnose the issue but it sounds like you should be checking the cell security for the cube where FY25 doesn't send and element security for the time dimension.
