I have a cube with one dimension having all leaf elements and one "total" element. To zero out a slice I want to use
DBS(0,"Cube", "Dim1", ...)
This doesn't work. There is no error, simply nothing happens. I also tryied
DBSW(0,"Cube", "Dim1", ...)
DBS("S0","Cube", "Dim1", ...)
DBSW("S0","Cube", "Dim1", ...)
DBS("P|0","Cube", "Dim1", ...)
DBSW("P|0","Cube", "Dim1", ...)
Unsuccesful. In view browser, I see the consolidated element as a gray cell and I can enter a "S0" or "S|0". So all leaf elements will be zerod out. So this feature worked, but not with DBS or DBSW.
Where is my problem?
BR
Dirk
Zero out with DBS on consolidated element
schlemiel29
- OLAP Product: TM/1
- Version: 11.8
- Excel Version: Excel 365
Re: Zero out with DBS on consolidated element
The DBS formula is cell specific so when you try updating the consolidation it is only trying to update that cell and it finds that it is a consolidation which means it is non updateable.
When you manually type into the cell with something like "C" or "S0" you are actually calling shortcuts to the spreading logic which is what makes it update the leaf cells under the consolidation; but the DBS formula doesn't have access to spreading.
You have a few options if you want to do a zero out from Excel; e.gg you could tell the user to enter the spreading shortcut or you could give them a process button to execute a TI that picks up the relevant elements via parameters and creates a view and does a zero out (technically you could also use the in-built spreading within the TI to run it at the C level directly but a viewzeroout will almost certainly be quicker.)
Hello Dirk,schlemiel29 wrote: ↑Tue Dec 17, 2024 9:14 am Hi all,
BR
Dirk
Would it be an option to follow a TM1/PA course with a partner where you live/work ?
That could well give you a boost in stepping up the learning curve, given the other topics you created too.
JohnO
- Version: 2.0.9.x
- Excel Version: Office 365 16
Try TM1VAL with the parameter to clear
You could also use CellPutProportionalSpread but you'll have to encapsulate within CellGetN <> 0. Not best practice by far, but it'll work
It's few lines of code but a real zero out (ViewZeroOut) is quicker.
Definitely, ViewZeroOut is by far the better option. It's just something that I used 20 years ago before I knew better
