TM1Web-Report sync with PAW visuals?
Posted: Thu Dec 05, 2024 10:30 am
by schlemiel29
In PAW I have the option to sync controls with each other by dimensions. When I define a Report in Excel and upload it to TM1Web, I can also use this in PAW as a visual. But its values are not offered outside to syncronize them.
I can save the selected elements in a special cube and make the other PAW controls to query from there, but is there a more convinient way to do it? Maybe there is a convention for naming ranges in the TM1Web report???
Re: TM1Web-Report sync with PAW visuals?
Posted: Fri Dec 06, 2024 1:03 pm
by Wim Gielis
The cells with SUBNM() formulas should synchronize in PAW and you can toggle which one you want to sync, if not all.
1 requirement though is that the SUBNM() cells should not be in hidden rows or columns.
