I have 2 dimensions with the same elements (Dim1 and Dim2)
First dimension Dim1 using in Setup_Cube where put some flags on some elements. Exist subset Sub1 which filter elements in Dim1 based on flags.
Is it possible to create MDX subset Sub2 in Dim2 which contains the same elements as Sub1 in Dim1?
May be based on flags on Setup_Cube - but it contain Dim1.
MDX in one dimension based on the subset of another dimension
EP_explorer
- OLAP Product: PAL
- Version: 2.0.9
burnstripe
- Version: 2.0.9
Re: MDX in one dimension based on the subset of another dimension
Yes it's possible, you could use the Generate function to do this. I'm not at a pc today but if noone comes back I can post an example tomorrow
MarenC
- Excel Version: Excel 2016
a non dynamic example would be:
{GENERATE(TM1SUBSETTOSET([Dim1], 'Sub1' ), {StrToMember("[Dim2].[" + [Dim1].currentmember.name + "]")})}
Maren
Maren
EP_explorer
- OLAP Product: PAL
- Version: 2.0.9
Thank you
It works
It works
MarenC
Though this one might be better just in case an element doesn't exist in the dimension:
{GENERATE(TM1SUBSETTOSET([Dim1], 'Sub1' ), FILTER(TM1FILTERBYLEVEL( {TM1SUBSETALL( [Dim2] )}, 0), [Dim1].Currentmember.name = [Dim2].Currentmember.name ))}
Maren
Maren
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
Heeey, that was one of my quiz questions! Maren could have earned another point
EP_explorer
- OLAP Product: PAL
- Version: 2.0.9
