Wondering if anyone has seen and found a solution for this. After disconnecting and reconnecting within excel a dynamic reports rebuild book fails
Scenario
* Dynamic form in Excel (any cube any data - as long as its dynamic)
* Normal refresh / rebuild book works OK (under 1 second)
* Disconnect and re-connect from TM1 from Excel
* rebuild report - takes 5 mins (exactly 5 mins to refresh)
Practically this happens when people time out due to inactivity (and it is a nuisance), above is an easy way to replicate the issue.
Any solutions that anyone can offer. Increase the time out will hide the issue but create others.
Dynamic report Rebuild Book - fails after disconnect / reconnect
Re: Dynamic report Rebuild Book - fails after disconnect / reconnect
If you are on the latest versions, I think this is one for IBM Support.
