CellPutN across the intersection of cube cells at once
syd
OLAP Product: PA/TM1, CX
Version: PA 2.0
Excel Version: MSO 365
Post by syd »
I have 10 cubes, each with a common dimension but varying in the number of dimensions from 4 to 12. When a new element is added to the common dimension, I want to assign a value of 1 to a specific measure element (which is available in all the measure dimensions). Is there a function (no rule, and want to write via TI process) to assign the value 1 for the new element across the intersection of cube cells at once?
Thank you,
syd
Re: CellPutN across the intersection of cube cells at once
syd wrote: ↑Thu Sep 19, 2024 5:13 pm Hi,
What is stopping you from having multiple CELLPUTN formulas in the same process? It's just a single line of code. That's how I would do it.
syd
Version: PA 2.0
Post by syd »
Each dimension has thousands of elements. Basically, I want to use the measured element as a feeder and avoid conditional feeders (sometimes over and under-feedings).
Thank you,
syd
MarenC
Excel Version: Excel 2016
Post by MarenC »
I assume the issue here is the time it takes to populate the flag feeder with a 1 and this isn't something that can be run 'out of hours'?
You could try using RunProcess or TM1RUNTI to run things in parallel, at least for the bigger cubes?
Maren
