Performance of View Zero Out
Emixam
Post by Emixam »
I started a project and one of the requirement was to be able to ViewZeroOut a very large data set (100,000,000+ cells). I never had to ViewZeroOut such a large data set and I noticed it takes around 10min.
I was wondering if there is a rule of thumb in term of number of cell per seconds that are VZO (ex: 50,000 cells per seconds) and what impacts the performance of ViewZeroOut. Any idea how to make it faster ?
I created a view using one of our generic TI with only level 0 and I skipped conso, rule and zeroes in the view creation.
ViewZeroOut('Cube Test', 'ViewName');
The cube have no rule.
Thanks and have a good day
Re: Performance of View Zero Out
You should always create a view with only level 0 and skipped consolidations, rules, zeroes.
The process }bedrock.cube.data.clear supports parallel clears:
https://github.com/cubewise-code/bedroc ... .clear.pro
That would be my next attempt.
John Hammond
Version: TM1 Server 11.8.003
Excel Version: 365 and 2016
Post by John Hammond »
Could be cube logging is on.
Also Much quicker to delete view via supporting dimension element deletion and re-insertion but this is not always possible.
Otherwise Mr Geilis and the bedrock libraries is your best bet.
