TM1 Rule issue using NUMBR() function
mlorini
Version: 2.8
Excel Version: 365
Post by mlorini »
I am experiencing the following issue with a rule file's NUMBR() function.
This rule works just fine it return the numeric value present in string 'S Value'
[ 'N Value' ] = N: NUMBR ( DB( 'Test' , !Test , 'S Value' )) ;
This rule does not works, it returns #N/A for any numeric value present in string 'S Value'
[ 'N Value' ] = N: NUMBR ( 'S Value' ) ;
Has anyone seen this odd TM1 behavior yet?
Re: TM1 Rule issue using NUMBR() function
mlorini wrote: ↑Mon Jul 22, 2024 3:17 pm I am experiencing the following issue with a rule file's NUMBR() function.
Under the 2nd option, you are trying to convert the text S Value into a number. It is not what you think (a measure containing stings that can easily be converted to numbers). At least this is what you think are trying to accomplish and where it goes wrong.
HighKeys
OLAP Product: TM1 / TM1 Web / Perspectives
Version: Planning Analytics V2.0.9
Post by HighKeys »
For me it looks like your 2nd Example is using the 's Value' Element from the same Cube, in that case you would need to write the rule like this:
[ 'N Value' ] = N: NUMBR ( ['S Value'] ) ;
HighKeys wrote: ↑Tue Jul 23, 2024 7:47 am For me it looks like your 2nd Example is using the 's Value' Element from the same Cube, in that case you would need to write the rule like this:
Nope that won't work. The square bracket shorthand notation is only valid for numeric values. To retrieve a string value the full DB() notation must be used.
[ 'N Value' ] = N: NUMBR ( DB('cubeName', 'Fixed Ref1', 'Fixed Ref2', !DynamicRef1, !DynamicRef2, 'S Value') ) ;
To get back to the OP's original question ...
I think Wim already answered this. In the example above 'S Value' is not a variable, it is a hardcoded literal string. As the string contains no numbers there is no numeric result. Therefore it isn't odd behavior but quite expected and mundane behavior.
On the other hand ...
NUMBR ( 'S Va1ue' )
... would return a value of 1.
mlorini
Version: 2.8
Excel Version: 365
Post by mlorini »
Wim Gielis, I'm having trouble understanding your answer. I believe I may not have explained my issue clearly. I'm seeking a clear explanation and a solution to the problem with the measures in the test cube.
My Test cube has two measures: one is named' S Value' and is a string, and the other is named 'N Value' and is numeric. (please check the attached screenshot) .
The rule [ 'N Value' ] = N: NUMBR (' S Value' ) is expected to convert the numeric value entered in' S Value' and assign it to the element 'N Value'.
Screenshot shows that if I enter 'S Value' = 5 I get 'N Value' = '#N/A'
Also,
[ 'N Value' ] = N: NUMBR (['S Value']) ; generate a syntax error.
mlorini wrote: ↑Tue Jul 23, 2024 12:56 pm Wim Gielis, I'm having trouble understanding your answer. I believe I may not have explained my issue clearly. I'm seeking a clear explanation and a solution to the problem with the measures in the test cube.
Also,
Sure it gives a syntax error.
If the first one works, why don't you stick with it ? It's correct.
What is it that makes you think you should use the second option (which does not work) ?
Also,
Please go back and read lotsaram's post. It answers your question completely.
mlorini
Version: 2.8
Excel Version: 365
Post by mlorini »
Well,
I was trying to apply some performance optimization to our rule. The following article explain that Replace DB with [‘element’] there is a 40% performance gain.
https://code.cubewise.com/blog/7-tips-t ... ics-rules/
Then the article could mention that this shorter syntax does not apply to String cells.
I.e., where the element in the last dimension of the cube is of type String.
