Turbo Integrator: dynamically switching from a text file to a view data source
A forum to post information about tools which are free and open source.
While I was playing around with some generic processes, I was testing the following setup.
A TI process has a text file data source type, taking the role of a template, from which we can dynamically change to other files / data sources like views, subsets, ODBC, etc.
I allow for 200 variables and mainly did that work in the *.PRO file for the process on the hard drive. Together with Notepad++ to increment series like 1 to 200, this was a breeze.
In the Advanced > Prolog tab of the process, it works fine when I want to dynamically override data source settings.
Then came the task to switch from a text file data source to a view data source. Oops, I got an error: "Variable "NVALUE" not found."
I know that NValue, SValue and Value_Is_String are special system variables: they are only available when the data source type is a view.
Hence, when switching to a view data source type, TM1 is still somehow expecting NValue, SValue and Value_Is_String.
If your process does not have code in the Metadata or Data tabs, then it runs fine (but is pretty useless!).
Once you have only 1 statement in the Metadata or Data tabs, then you receive the error right into your face.
Luckily, Google lead me to viewtopic.php?p=53278#p53278 (lotsaram, Wed Jan 07, 2015 1:00 pm) in the quite long topic found at: viewtopic.php?t=5170
Lotsaram and others were discussing there how to dynamically make the switch. AmbPin had the exact same question (and error) as me. It was suggested that the switch should start from a view data source, not from the text file data source.
This does not particularly please me. Why not have a TI process with a text file data source and still being able to make the switch ?
I found out that this is possible. You need to stop the TM1 model and go to the TI process on the hard drive. Open it up in Notepad++ or a different text editor.
You will notice codes. Be careful to only edit the PRO file where I instruct it. Here are the necessary changes/additions:
In the section for 577, add 3 to the count of lines, and add at the end:
NValue
SValue
Value_Is_String
In the section for 578, add 3 to the count of lines, and add at the end:
1
2
1
In the section for 579, add 3 to the count of lines, and add at the end:
0
0
0
In the section for 580, add 3 to the count of lines, and add at the end:
0
0
0
In the section for 581, add 3 to the count of lines, and add at the end:
0
0
0
In the section for 582, do not change anything !
The count of lines always follows with a comma after the code number (577, 578, ...).
When you are ready, save the PRO file and start the TM1 model again. Now the 3 built-in variables NValue, SValue and Value_Is_String are available.
At the time of dynamically switching to a view data source, all is set and you are good to go.
@rclapp commented that it might be possible to do it with the TM1 REST API. I did not check that out, that's something for tomorrow.
Wim
Re: Turbo Integrator: dynamically switching from a text file to a view data source
Ryan was correct (no doubt about that one!)
Here is the JSON body to use in the TM1 REST API to set the variables:
- 200 string variables: V1 to V200
- NValue as a numeric variable
- SValue as a string variable
- Value_Is_String as a numeric variable
{"Variables": [
            "Name": "V1",
            "Type": "String",
            "Position": 1,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V2",
            "Type": "String",
            "Position": 2,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V3",
            "Type": "String",
            "Position": 3,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V4",
            "Type": "String",
            "Position": 4,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V5",
            "Type": "String",
            "Position": 5,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V6",
            "Type": "String",
            "Position": 6,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V7",
            "Type": "String",
            "Position": 7,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V8",
            "Type": "String",
            "Position": 8,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V9",
            "Type": "String",
            "Position": 9,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V10",
            "Type": "String",
            "Position": 10,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V11",
            "Type": "String",
            "Position": 11,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V12",
            "Type": "String",
            "Position": 12,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V13",
            "Type": "String",
            "Position": 13,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V14",
            "Type": "String",
            "Position": 14,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V15",
            "Type": "String",
            "Position": 15,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V16",
            "Type": "String",
            "Position": 16,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V17",
            "Type": "String",
            "Position": 17,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V18",
            "Type": "String",
            "Position": 18,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V19",
            "Type": "String",
            "Position": 19,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V20",
            "Type": "String",
            "Position": 20,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V21",
            "Type": "String",
            "Position": 21,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V22",
            "Type": "String",
            "Position": 22,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V23",
            "Type": "String",
            "Position": 23,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V24",
            "Type": "String",
            "Position": 24,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V25",
            "Type": "String",
            "Position": 25,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V26",
            "Type": "String",
            "Position": 26,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V27",
            "Type": "String",
            "Position": 27,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V28",
            "Type": "String",
            "Position": 28,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V29",
            "Type": "String",
            "Position": 29,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V30",
            "Type": "String",
            "Position": 30,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V31",
            "Type": "String",
            "Position": 31,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V32",
            "Type": "String",
            "Position": 32,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V33",
            "Type": "String",
            "Position": 33,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V34",
            "Type": "String",
            "Position": 34,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V35",
            "Type": "String",
            "Position": 35,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V36",
            "Type": "String",
            "Position": 36,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V37",
            "Type": "String",
            "Position": 37,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V38",
            "Type": "String",
            "Position": 38,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V39",
            "Type": "String",
            "Position": 39,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V40",
            "Type": "String",
            "Position": 40,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V41",
            "Type": "String",
            "Position": 41,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V42",
            "Type": "String",
            "Position": 42,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V43",
            "Type": "String",
            "Position": 43,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V44",
            "Type": "String",
            "Position": 44,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V45",
            "Type": "String",
            "Position": 45,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V46",
            "Type": "String",
            "Position": 46,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V47",
            "Type": "String",
            "Position": 47,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V48",
            "Type": "String",
            "Position": 48,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V49",
            "Type": "String",
            "Position": 49,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V50",
            "Type": "String",
            "Position": 50,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V51",
            "Type": "String",
            "Position": 51,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V52",
            "Type": "String",
            "Position": 52,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V53",
            "Type": "String",
            "Position": 53,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V54",
            "Type": "String",
            "Position": 54,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V55",
            "Type": "String",
            "Position": 55,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V56",
            "Type": "String",
            "Position": 56,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V57",
            "Type": "String",
            "Position": 57,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V58",
            "Type": "String",
            "Position": 58,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V59",
            "Type": "String",
            "Position": 59,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V60",
            "Type": "String",
            "Position": 60,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V61",
            "Type": "String",
            "Position": 61,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V62",
            "Type": "String",
            "Position": 62,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V63",
            "Type": "String",
            "Position": 63,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V64",
            "Type": "String",
            "Position": 64,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V65",
            "Type": "String",
            "Position": 65,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V66",
            "Type": "String",
            "Position": 66,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V67",
            "Type": "String",
            "Position": 67,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V68",
            "Type": "String",
            "Position": 68,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V69",
            "Type": "String",
            "Position": 69,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V70",
            "Type": "String",
            "Position": 70,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V71",
            "Type": "String",
            "Position": 71,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V72",
            "Type": "String",
            "Position": 72,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V73",
            "Type": "String",
            "Position": 73,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V74",
            "Type": "String",
            "Position": 74,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V75",
            "Type": "String",
            "Position": 75,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V76",
            "Type": "String",
            "Position": 76,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V77",
            "Type": "String",
            "Position": 77,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V78",
            "Type": "String",
            "Position": 78,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V79",
            "Type": "String",
            "Position": 79,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V80",
            "Type": "String",
            "Position": 80,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V81",
            "Type": "String",
            "Position": 81,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V82",
            "Type": "String",
            "Position": 82,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V83",
            "Type": "String",
            "Position": 83,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V84",
            "Type": "String",
            "Position": 84,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V85",
            "Type": "String",
            "Position": 85,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V86",
            "Type": "String",
            "Position": 86,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V87",
            "Type": "String",
            "Position": 87,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V88",
            "Type": "String",
            "Position": 88,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V89",
            "Type": "String",
            "Position": 89,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V90",
            "Type": "String",
            "Position": 90,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V91",
            "Type": "String",
            "Position": 91,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V92",
            "Type": "String",
            "Position": 92,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V93",
            "Type": "String",
            "Position": 93,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V94",
            "Type": "String",
            "Position": 94,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V95",
            "Type": "String",
            "Position": 95,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V96",
            "Type": "String",
            "Position": 96,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V97",
            "Type": "String",
            "Position": 97,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V98",
            "Type": "String",
            "Position": 98,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V99",
            "Type": "String",
            "Position": 99,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V100",
            "Type": "String",
            "Position": 100,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V101",
            "Type": "String",
            "Position": 101,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V102",
            "Type": "String",
            "Position": 102,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V103",
            "Type": "String",
            "Position": 103,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V104",
            "Type": "String",
            "Position": 104,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V105",
            "Type": "String",
            "Position": 105,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V106",
            "Type": "String",
            "Position": 106,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V107",
            "Type": "String",
            "Position": 107,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V108",
            "Type": "String",
            "Position": 108,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V109",
            "Type": "String",
            "Position": 109,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V110",
            "Type": "String",
            "Position": 110,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V111",
            "Type": "String",
            "Position": 111,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V112",
            "Type": "String",
            "Position": 112,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V113",
            "Type": "String",
            "Position": 113,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V114",
            "Type": "String",
            "Position": 114,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V115",
            "Type": "String",
            "Position": 115,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V116",
            "Type": "String",
            "Position": 116,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V117",
            "Type": "String",
            "Position": 117,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V118",
            "Type": "String",
            "Position": 118,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V119",
            "Type": "String",
            "Position": 119,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V120",
            "Type": "String",
            "Position": 120,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V121",
            "Type": "String",
            "Position": 121,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V122",
            "Type": "String",
            "Position": 122,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V123",
            "Type": "String",
            "Position": 123,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V124",
            "Type": "String",
            "Position": 124,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V125",
            "Type": "String",
            "Position": 125,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V126",
            "Type": "String",
            "Position": 126,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V127",
            "Type": "String",
            "Position": 127,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V128",
            "Type": "String",
            "Position": 128,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V129",
            "Type": "String",
            "Position": 129,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V130",
            "Type": "String",
            "Position": 130,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V131",
            "Type": "String",
            "Position": 131,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V132",
            "Type": "String",
            "Position": 132,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V133",
            "Type": "String",
            "Position": 133,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V134",
            "Type": "String",
            "Position": 134,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V135",
            "Type": "String",
            "Position": 135,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V136",
            "Type": "String",
            "Position": 136,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V137",
            "Type": "String",
            "Position": 137,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V138",
            "Type": "String",
            "Position": 138,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V139",
            "Type": "String",
            "Position": 139,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V140",
            "Type": "String",
            "Position": 140,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V141",
            "Type": "String",
            "Position": 141,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V142",
            "Type": "String",
            "Position": 142,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V143",
            "Type": "String",
            "Position": 143,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V144",
            "Type": "String",
            "Position": 144,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V145",
            "Type": "String",
            "Position": 145,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V146",
            "Type": "String",
            "Position": 146,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V147",
            "Type": "String",
            "Position": 147,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V148",
            "Type": "String",
            "Position": 148,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V149",
            "Type": "String",
            "Position": 149,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V150",
            "Type": "String",
            "Position": 150,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V151",
            "Type": "String",
            "Position": 151,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V152",
            "Type": "String",
            "Position": 152,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V153",
            "Type": "String",
            "Position": 153,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V154",
            "Type": "String",
            "Position": 154,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V155",
            "Type": "String",
            "Position": 155,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V156",
            "Type": "String",
            "Position": 156,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V157",
            "Type": "String",
            "Position": 157,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V158",
            "Type": "String",
            "Position": 158,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V159",
            "Type": "String",
            "Position": 159,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V160",
            "Type": "String",
            "Position": 160,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V161",
            "Type": "String",
            "Position": 161,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V162",
            "Type": "String",
            "Position": 162,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V163",
            "Type": "String",
            "Position": 163,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V164",
            "Type": "String",
            "Position": 164,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V165",
            "Type": "String",
            "Position": 165,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V166",
            "Type": "String",
            "Position": 166,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V167",
            "Type": "String",
            "Position": 167,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V168",
            "Type": "String",
            "Position": 168,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V169",
            "Type": "String",
            "Position": 169,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V170",
            "Type": "String",
            "Position": 170,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V171",
            "Type": "String",
            "Position": 171,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V172",
            "Type": "String",
            "Position": 172,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V173",
            "Type": "String",
            "Position": 173,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V174",
            "Type": "String",
            "Position": 174,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V175",
            "Type": "String",
            "Position": 175,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V176",
            "Type": "String",
            "Position": 176,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V177",
            "Type": "String",
            "Position": 177,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V178",
            "Type": "String",
            "Position": 178,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V179",
            "Type": "String",
            "Position": 179,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V180",
            "Type": "String",
            "Position": 180,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V181",
            "Type": "String",
            "Position": 181,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V182",
            "Type": "String",
            "Position": 182,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V183",
            "Type": "String",
            "Position": 183,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V184",
            "Type": "String",
            "Position": 184,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V185",
            "Type": "String",
            "Position": 185,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V186",
            "Type": "String",
            "Position": 186,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V187",
            "Type": "String",
            "Position": 187,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V188",
            "Type": "String",
            "Position": 188,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V189",
            "Type": "String",
            "Position": 189,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V190",
            "Type": "String",
            "Position": 190,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V191",
            "Type": "String",
            "Position": 191,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V192",
            "Type": "String",
            "Position": 192,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V193",
            "Type": "String",
            "Position": 193,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V194",
            "Type": "String",
            "Position": 194,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V195",
            "Type": "String",
            "Position": 195,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V196",
            "Type": "String",
            "Position": 196,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V197",
            "Type": "String",
            "Position": 197,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V198",
            "Type": "String",
            "Position": 198,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V199",
            "Type": "String",
            "Position": 199,
            "StartByte": 0,
            "EndByte": 0
            "Name": "V200",
            "Type": "String",
            "Position": 200,
            "StartByte": 0,
            "EndByte": 0
            "Name": "NValue",
            "Type": "Numeric",
            "Position": 201,
            "StartByte": 0,
            "EndByte": 0
            "Name": "SValue",
            "Type": "String",
            "Position": 202,
            "StartByte": 0,
            "EndByte": 0
            "Name": "Value_Is_String",
            "Type": "Numeric",
            "Position": 203,
            "StartByte": 0,
            "EndByte": 0
Devil's advocate here. Why do you need rest API? Wouldn't you get exactly the same result if you just used a text file with 202 columns and simply renamed the last 3 variables?
That's an option too :-) Making sure that 2 are Numeric, 1 is String.
You could use an Excel file, write V1 and drag it across. Then change the last couple of variables.
Save as TXT and use as the source of a TI process.
Wim Gielis wrote: Fri Jul 05, 2024 2:17 am Then came the task to switch from a text file data source to a view data source. Oops, I got an error: "Variable "NVALUE" not found."
IBM confirmed that this error will be solved in the latest 2.1.3 release (not out yet).
