Hi there
I am importing data from a SQL table into a cube, and using CellIncrementN. For some reason I am getting a really small number with a huge number of decimals e.g. 0.000000000000023
I have tested by running the source query in SQL and pasting to Excel. The 16 rows that are returned all display with 2 decimals, and aggregate to 0 (as they should). I have also used RoundP(Value,2) in my Call Increment. The problem still remains.
Any ideas?
Many thx!
Large number of Decimals - unexpected
- gtonkin
Re: Large number of Decimals - unexpected
Will point you to one of Steve's posts which will point you to others.
Basically down to floating point imprecision.
An IBM post
An IBM post
- Version: 9.5
- Excel Version: 7
Thanks George!
I have a rule which divides by the value. This then becomes a real issue as you get massive calculated numbers.
Worked my way around this in a rule.
