Use of + in Element names
Posted: Fri Jun 21, 2024 12:41 am
I know that the use of + as the first character of an Element name is not recommended/supported as per the following from IBM.
"Element names and MDX expressions
Do not use + or - as the first character of an element name. Although only the first element in a subset when slicing to active form cannot use + or - as the first character in the element name, it is a good practice to never use + or - as the first character of an element name."
But using it elsewhere in the name, has anyone had problems with PAW & PAfE? (Other than the issue currently being experienced with TM1SET)
