Average calculation using TI process
Posted: Fri May 31, 2024 4:13 am
Just looking for some advice on the best way to write a TI that is calculating historical averages based on a range of periods, then inserting that calculated value to a specified future month.
Here are some more details:
I have 2 parameters in my TI process ( pAvgYrStart and pAvgYrEnd).
These values can be any range of years but for this example we’ll use 2021 to 2023.
I also have 2 parameters which define the forecast start and end period ( pFcstStartPeriod and pFcstEndPeriod). This is to tell the TI which periods to paste the values against. For this example we’ll use Jan-2024 to Dec-2024.
The average calculation is quite simple in that if the user inserts a range of 3 years as in the example above, the process needs to look back at the 3 previous January months, sum them together and divide by 3. Then insert this value into Jan-2024. And the same goes for all periods in the Forecast start to end range.
I am able to calculate the denominator of this equation whether then users inputs 3 years or 10 years by just subtracting the pAvgYrEnd from pAvgYrStart but I’m running into a mental block with the numerator part of this equation.
Where I’m getting stuck is accumulating the values in the numerator and then inserting them to the corresponding future period. Jan-2021 + Jan-2022 + Jan-2023 / 3 should be placed into Jan-2024 and so on for all the rest of the periods.
Any advice or thoughts on how to approach this would be greatly appreciated.
Thanks in advance!
Thanks in advance!
