using cellput to put the same value in 2 element values
M1ndbender
Version: 2.0.0
Excel Version: 365
Post by M1ndbender »
I have a cell put on the data tab of a process. What i need is the Rate Value to be put against 2 elements.
Where it says if SourceNum @= 1 I want to put that Rate into values of 1 and 3 in the Price Rate dimension
Everything I have tried has not worked and google has been no help. Is this possible?
IF (vSourceNum @= '1');
    CellPutN( Value,
        vTargetCube,
        Period,
        vcompany ,
        '1',  AND 3
        product,
        'Rate');
ELSEIF (vSourceNUM @= '2');
    CellPutN( Value,
        vTargetCube,
        Period,
        vcompany ,
        '2',
        product,
        'Rate');
ENDIF;
MarenC
Excel Version: Excel 2016
Re: using cellput to put the same value in 2 element values
Post by MarenC »
Why not have 2 cellputs within the
section;? One for Price Rate 1 and one for Price Rate 3?
Maren
Adam
OLAP Product: IBM PA
Version: 2.0.9.x
Post by Adam »
Try repeating CellPutN function, once with ‘1’ AND once with ‘3’.
Take care,
Adam
M1ndbender
Version: 2.0.0
Excel Version: 365
Thank you. I did not try putting 2 cellputs under the if. I had tried a second if with the same criteria that did not work.
This appears to be working now
Thank you for the help
