log file for tm1a.exe
Posted: Mon Apr 29, 2024 11:36 am
by wang_chris
I just installed PA 2.0.9.19 on windows 10 Home edition (edition ID : 22H2).
TM1 server and admin server can be started successfully.
However, tm1 admin client (tm1a.exe) can not be run successfully. Windows event viewer always reports crash when trying to load tm1p.dll with exception code '0xc000041d', but without any further message.
Does anyone has an idea to overcome this error?
Re: log file for tm1a.exe
Posted: Mon Apr 29, 2024 3:49 pm
Your OS seems a little outdated ...
Won't help with your issue but just for clarity:
- tm1a.exe is architect
- admin server is tm1admsrv.exe (or tm1admsd.exe for the service runner)
Are you attempting to use the 32 bit version from bin or the 64 bit version from bin64?
There have been issues in the past with TM1 installers not registering all of the dlls which they need. Maybe this issue has reoccurred? Check that the following files are present in the bin/bin64 directory and are registered in regsvr.
- tm1p.dll
- tm1prc.dll
- tm1dasrv.dll
If you are also wanting to run Perspectives locally then you might also need
- tm1xl.ocx
Posted: Mon Apr 29, 2024 8:16 pm
by wang_chris
maybe this is the issue.
I can not find file 'tm1dasrv.dll' under folder 'bin64' (my system is 64bit windows). where can I get this file? I have picked up 'perspective' in installation panel.
Thanks for your advice, lotsaram.
Posted: Mon Apr 29, 2024 8:43 pm
by wang_chris
In addition, system reports error massage 'tm1p.dll load fail' when I try to run command:
- regsvr32 d:\ibm\cognos\tm1_64\bin64\tm1p.dll
Posted: Sun May 12, 2024 6:15 am
by konstantin-spb
