How can promote my workbench form an environment to another (for ex from DEV env to UAT env) ? (without recreating it obviously)
Many thanks
promote workbench from an env to another
- Steve Rowe
Re: promote workbench from an env to another
You can use Lifecycle Administration for this. There's also a method where you can get to the JSON and edit replace the server name but I forget the shortcut to get to the JSON. I'm sure someone will be along shortly to tell you.
Ctrl q /
Does this work for you ?
Many thanks !
@Wim : the shorcut ctr q / works only for promoting books (I already use it)
@Steve : the method that you mention is working only for promoting books as Wim said it's the ctr q / shortuct. What about the other method ? Can you explain for me how to do it ?
Many thanks !
Did you have a look at the Administration part and the Lifecycle manager ?
- gtonkin
Hi SYPA,
On PAW 2.0.94 onwards you can migrate workbenches between Dev and Prod for example.
What version are you using?
I'm using 2.0.89.
I'm using 2.0.89.
- gtonkin
Apparently supported from 2.0.87
https://www.ibm.com/docs/en/planning-an ... -snapshots
